Drag and Drop Functionality for Blocks within a Note
I’ve been actively using the app, and I’ve noticed that organizing ideas within my notes could be significantly improved with the ability to drag and drop text blocks. I’ve done some exploration through Discord, this forum, and the Help files but couldn’t find a definitive answer about the current availability of this feature.
The current method of reordering blocks involves cutting and pasting, which can be quite labor-intensive, especially when managing comprehensive notes. I am aware of the alt + Up/Down arrow hotkey for swapping lines, but this isn’t quite what I’m looking for.
I would like to suggest the implementation of a drag-and-drop feature for blocks of text. This functionality would save a considerable amount of time and enhance the organization of ideas, making the workflow smoother and more intuitive.
Expected Functionality:
  1. Reordering within the Same Note: Ability to drag a block to a new position within the same note for seamless reorganization.
  2. Moving to Another Note: Dragging a block to a different note would either create a new block ID or use an existing one, embedding the block in the target file using the appropriate linking syntax.
  3. Copying Blocks: Holding a modifier key like “Shift” could duplicate the block instead of moving it.
None
Previous Discussions & Attempts:
  • There have been multiple requests for this feature last year, but I haven’t found any confirmation or updates on their status.
  • I found references to a similar request for drag and drop of bullets and headings.
  • There was an existing plugin that facilitated this to some extent, though it appears to be no longer functional.
Thank you for considering this request, and any updates or insights would be greatly appreciated!
Workaround for rearraging headings is Outline core plugin:
To rearrange sections in the note, click and drag the heading within the outline.
This is very close to your request if you are willing to name your text blocks using headings.
Really missing this feature too.
I really want this.
I brainstorm blog posts by creating tiny blocks of text and dragging them around to compose the article so that every thought flows from the previous one. It is absolutely not the same as re-arranging headers, I need to re-arrange blocks of text.
Please please please add this, I am sure there are lots of people who want this despite small amount of upvotes.
Have you tried this plugin GitHub - slnsys/obsidian-canvas2document: Plugin for Obsidian to convert a complete Canvas to a long form document
Basically the idea is to utilize canvas to brainstorm then use some plugin to convert the content from your nodes. I think this can be actually a functional idea because canvas already implements way to zoom out/in making it intuitive to work with node arrangement. Compared to this feature request canvas already scales well to arranging tens of nodes with arbitrary text length.
Well that’s cool but it’s like inventing a bicycle. It feels like an essential function for an app like this, and I am extremely surprised it is not requested more often, even though my friends often talk about it privately.
It’s like ‘our app doesn’t support moving files to folders so you have to create a copy of the file and then delete the original’.
