Drag and drop from icon library base to excalidraw
Hey, I imitated Zsolt Viczian’s icon library base.
I have no problem seeing my icons in the base. But when I try to drag to my excalidraw, they appear as ![[example.svg]]
What should I fix to see them as icons themselves?
Thank you,
When you try to drag an .svg item to Excalidraw, press Shift (or try Ctrl, Cmd etc. I’m not sure if it’s same in every computer) while dropping it.
