Double Click - New Note - Possible?
Hi,
I’ve searched the forum, and the community plugins, but I can’t find what I’m after. I apologise if it’s sticking out like a sore thumb and/or I’m blind.
I use Sublime Text and one of the nice little features I like about it is I can double click the titlebar area and get a new blank document.
Is there some way I can have the same in Obsidian? I’m after a way to double click the empty area and have the Command-N command be run.
For example if I double clicked here:
Thanks very much and I do apologise again if my searching has let me down.
Kind Regards,
Tim
You are right, no community plugins exists to configure custom action for double clicking empty tab area. Such community plugin is not needed though because you can use Commander to place custom actions as icons. That is almost the same as double clicking existing GUI element.
Hi @blue_emperor I appreciate the reply, thank you.
I don’t actually need a plugin to create a button though, one exists already:
I’m not sure if that’s a plugin I’ve got, or just the default setting.
So yes, I can seek out and click a button. I was just hoping I could double-click, it’s real muscle memory I have from my Subline use and I was hoping to bring it to Obsidian.
Kind Regards,
Tim
Hi. You have two options. You can either post to Feature requests or Plugins ideas. If you are a programmer yourself then you might want to post Developers: Plugin & API.
Thanks @blue_emperor - I guess I was just looking for confirmation there’s no current way to do it. I don’t think my small wish is worth bothering others about. If it was a popular idea it’d have been done already :slight_smile:
Thanks for your help!
Tim
