Hello.
I’m using Fedora 39 and Obsidian installed via flatpak.
I’ve been going crazy trying to get “y” and “p” to yank and paste to the system clipboard.
The best instructions I can find are to use the .vimrc plugin here: GitHub - esm7/obsidian-vimrc-support: A plugin for the Obsidian.md note-taking software
And add something similar to:
" Yank to system clipboard (when using the 'y' key to yank)
set clipboard=unnamedplus
To a .obsidian.vimrc file in my vault’s root.
I’ve tried every combination of the ‘clipboard=’ directives I can find. I can’t seem to get this to work.
I have resorted to just using ctrl-c and ctrl-p to copy and paste, but it throws me off so bad since I edit text/code in vim all day and then I always forget that “y” and “p” will not work.
Here is my obsidian.vimrc file.
" map y "+y
unmap <C-c>
iunmap <C-c>
unmap <C-p>
iunmap <C-p>
Any help would greatly be appreciated.
