Does anchor linking not work?
Hi all, I’ve tried using this way of anchor linking:
i.e. write the link
text
and set the link some text
this doesn’t work however, am I misunderstanding the discussion above or has this changed?
Are there alternatives?
I am exporting the note to HTML and I’d love for it to be a correct working anchor link, it seems that block links doesn’t translate to anchor links when exporting.
Many thanks in advance!
The zip attached has a Markdown file and and an HTML version of the same file.
The first same-page link works in Obsidian.
The second same-page link works when exported to HTML.
What you want?
sample.zip (6.7 KB)
I noticed that it works when exporting, I was hoping that it would also work in obsidian directly?
edit: but if it doesn’t then its clear I misunderstood the conversation I linked to before.
AFAIK only the same-page wiki-style links (the first link in the sample file) work in Obsidian. Same-page HTML anchor links only work when exported.
I see, thanks, I did misunderstand then. Too bad because the block links don’t work on export. Cheers!
