Documents "go blank" using Obsidian Sync
  • I dont’ think there are any steps,
Tried in Sandbox vault, was unable to replicate.
Daily Notes show up blank at least once a week
Obsidian version: v1.9.4
Installer version: v1.8.9
Operating system: Darwin Kernel Version 24.5.0: Tue Apr 22 19:54:49 PDT 2025; root:xnu-11417.121.6~2/RELEASE_ARM64_T6000 24.5.0
Catalyst license: supporter
Insider build toggle: on
Base theme: light
Community theme: Minimal v7.7.19
Snippets enabled: 7
Plugins installed: 63
Plugins enabled: 54
1: Callout Manager v1.1.0
2: Callout Suggestions v1.0.2
3: Paste URL into selection v1.7.0
4: Regex Find/Replace v1.2.0
5: Excalidraw v2.11.1
6: Dataview v0.5.68
7: Templater v2.11.3
8: Advanced Tables v0.22.1
9: Recent Files v1.7.4
10: Advanced URI v1.44.3
11: Calendar v1.5.10
12: Natural Language Dates v0.6.2
13: Note Toolbar v1.23.10
14: Periodic Notes v0.0.17
15: Style Settings v1.0.9
16: Supercharged Links v0.12.1
17: Toggl Track v0.11.0
18: Sortable v0.2.6
19: Shortcut Launcher v1.1.0
20: QuickAdd v1.13.3
21: Projects v1.17.4
22: Plugin Reloader v0.0.3
23: Pixel Banner v3.5.5
24: Note Refactor v1.8.2
25: Mononote v1.2.2
26: MetaEdit v1.8.2
27: Meta Bind v1.4.1
28: Media DB v0.8.0
29: Actions URI v1.7.3
30: Auto Link Title v1.5.5
31: Charts v3.9.0
32: Editor Syntax Highlight v0.1.3
33: File Info Panel v1.3
34: Global Search and Replace v0.5.0
35: Heatmap Calendar v0.7.1
36: Link Embed v2.5.5
37: Settings Search v1.3.10
38: Day Planner v0.27.0
39: Reminder v1.1.19
40: Metadata Menu v0.8.9
41: Homepage v4.2.2
42: Minimal Theme Settings v8.1.1
43: Multi-Column Markdown v0.9.1
44: Kanban v2.0.51
45: Widgets v0.0.11
46: Journals v2.1.9
47: Update time on edit v2.4.0
48: Visual Crossing Weather v1.1.5
49: Dynamic Embed v1.1.0
50: TaskNotes v2.0.4
51: Digital Garden v2.59.0
52: Tag Wrangler v0.6.4
53: Tasks v7.20.0
54: Task Genius v9.0.6
For some reason, about once a week, I open one of my daily notes and it’s just blank. I create all my notes using automation (creates a text file and saves it into my vault folder), so my notes are made a week or two ahead of time.
I use Obsidian Sync. My daily note has no real data, it’s all Bases and Dataviews and external file references, so rebuilding the note is simply re-applying the template - but it’s super annoying.
I looked at the version history (screenshots attached), and I don’t see where the data is going. I created this note on June 30, and nothing touched it until July 6 - which is when I opened it and it was blank.
can you expand the first two items in the last screenshot?
Is this enabled and active on all devices?
I expanded each section, and can’t find any correlation. There’s “8 revisions via Work Laptop” on June 30 at 4:54PM, then the next entry is July 6 at 3:31PM when it’s blank. There is no activity on this note on any other device either. I suspect @Sigrunixia 's theory about the Update Time of Edit is the culprit. I do notice that this plugin is too aggressive on “fixing” things that are not really broken in front matter.
Update on Edit plugin is enabled on 2 devices. I’m going to try disabling it on my phone and see if that helps (although I will lose an updated time on mobile it will eventually catch up when my desktop syncs…)
do you have any updates on this?
templeter is sometimes also associated with these types on bugs
