Per Obsidian’s website:
You can connect multiple local vaults to your remote vault. When you make a change to a local vault, that change is saved to the connected remote vault. Your change is then synced across all the local vaults you’ve connected to that remote vault.
I’m a bit confused about what this means (I just paid for a one month trial of Sync Plus). Does this mean I get 10 remote vaults? Or do I get one remote vault that I can connect with up to 10 local vaults? If I get 10 remote vaults, can I connect as many local vaults as I want to those 10 remote vaults? I’m also very confused about how shared vaults would work in this context.
