I’d like to be able to manually verify plugin updates for security reasons. If I install a community plugin right now, would it auto-update in the background without telling me? Or do I have to manually check for updates in that tab in the settings?
If it does auto-update, is there a way to turn it off?
They don’t update on their own. You can click on check for updates in the community plugin settings and then you can choose to update the plugins one by one.
