Hi, that’s correct, with 1.17 the internal behavior of the layouting engine changed, elements bounding boxes are now only as big as the element, therefore text-align seams not to work, because the box and the text in the box have the same width and therefore the alignment doesnt change.
Happy to discover Advanced Slides. I’ve made a few reveal.js presentations before and am so happy I can work directly in Obsidian.
A few questions:
how do i access the export options? i’ve been through the forum and can’t find the ‘three dots’. there is the slide-out menu accessed from the three lines. i can also open it with the M key. in the menu, my only options across the top are Slides and Close. I can’t find anything about printing or saving as html. What am I missing?
is it possible to embed a functioning presentation directly in Obsidian Publish? Once I can get the save to html working, I know I can export out and host on github and then embed in an Obsidian note. Would love to have it working natively without the external hosting hassle.
Thanks for building this and for what seems to be pretty good interaction with the users. The world needs more active developers like you.
Hello everyone. I’m new to advanced slide and I tried to publish it online in github. manage to get it published but the content was not there. this is my gitgub file. any tips is greatly appreciated
hi i have the same issue, but it didn’t improve when changing the file names I can create slides, but the content is not shown. Any suggestions? I run macOS Monterey 12.6. on M1 Max.
Today I released version 1.18.0. With this version, Advanced Slides supports Obsidian 1.0.0
Highlights:
Compatible with Obsidian 1.0.0
Features
feature: added mermaid gitgraph support (#136)
feature: added Laser Pointer plugin
feature: mermaid diagrams now support darkMode (#128)
feature: allow mermaid configuration through frontmatter
feature: added frontmatter property defaultTemplate. DefaultTemplate allows you to apply a template to all slides you created in this deck (#131)
feature: Added setting to configure slide preview mode. You can now decide how the slide preview panel should be display, as workspace slide (default configuration as in Obsidian 0.15 and before), as new tab or new window
Fixes
bugfix: Set center: false cannot align everything to the left (#133)
bugfix: MathJax aligned environment breaks in templates (#132)
bugfix: image rendering causes markdown processor to skip transformation of next text block (#129)
Documentation
docs: added documentation on laser pointer plugin (#135)
docs: added documentation on defaultTemplates
docs: added SaturdayShowcase to Learn more Section: SaturdayShowcase is a weekly format where the Advanced Slides developers feature presentations of their users.
hi - I enjoy the plugin a lot, primarily for its ability to quickly create a few slides from a few lines of markdown.
I keep running into the situation where I need to add html tags to adjust the font size for a slide, where I expected it to do a form of auto-adjust to fit on the slide.
E.g., the following simple slide doesn’t fit on a page when I present in a browser. (It does look ok in the slide preview)
Budget Needs
Team
Budget Needs
Research
$100K
Support
$80K
Prod Dev 1
$50K
Prod Dev 2
$160K
Release Engineering
$165K
Infrastructure
$250K
Footnote
The result is that I need to add and table formatting html to my markdown. I wanted to avoid all that.
Shouldn’t the font size have auto-adjusted in the browser?
Well that’s not as easy as you think, responsive html design as you see in the internet is pretty descriptive. Without any layout-information the rendering part doesnt know which column should take the empty space that’s there, or if an image that is part of the table should be scaled down to fit the column or extend the column, and if it’s get extended should text in another column rendered in multiple lines or should it stay in a single line… and so on…
The table renderer tries to render a table as best as possible ( it extends the with of the table to the width of the slide, which could cause the result that you described )
I whould suggest to wrap the table in an anonymous block and annotate the block with a fixed font size
::: block
First Header | Second Header
Content from cell 1 | Content from cell 2
Content in the first column | Content in the second column
::: <!-- element style="font-size:16px" -->
Very cool features ! Thank you
I have a question, one of my notes shows the images in Markdown, in the slide preview the images are missing, but in the presentation the images are there. Trying to find out why the images are not present in the slide preview. Do you have an idea? Happy to send you the note if you provide an email address
thank you for the suggestion, unfortunately that did not work. Thankfully, the images are present in the presentation, not being able to see them in the slide preview is of course a bit of a hassle.
Hi, I am running into two issues using Advanced Slides.
When I switch on the laser pointer option, the slide preview is blank.
I am not seeing any button or menu options to export the slides to HTML. Here’s a screenshot of the Markdown source and the preview pane for a presentation:
