Unfortunately I have to disappoint you, there is no way to convert slides from Power Point to Advanced Slides. The reason for this is the philosophy behind both approaches. Power Point uses a WYSIWYG philosophy, i.e. all layout settings can and must be configured by the user to create a slide. Advanced Slides uses a “convention over configuration” approach. This means that many of the settings that exist are made by Advanced Slides depending on the context of the respective element that is to be displayed. This makes it possible for simple markdown to be transformed into complex slides.
I would recommend you to manually convert your power point deck to advanced slides and then abstract that by extracting the layout information into a templates that you can reuse.
In the next step, you abstract the information in the slide into atomic notes and embed them in the slide, so you avoid redundancy in your notes
Advanced Slides Preview & the output to the browser stopped working after today’s Obsidian update 0.15.6 Do you think that is related to the update or would you need more data to troubleshoot?
plugin:obsidian-advanced-slides:299 Uncaught (in promise) Error: ENOENT: no such file or directory, open ‘/Users/macpro/Documents/@OBSIDIAN/@HOME/.obsidian/plugins/obsidian-advanced-slides/template/reveal.html’
Thanks for this great plugin! I’ve been really enjoying it for creating a presentation that I will be giving at an upcoming conference!
I do have a question. Is it possible to write text in the note/slide that isn’t considered to be part of the slide? For Excalidraw I believe that anything before the first header isn’t considered part of the drawing. Maybe something somewhat similar could here.
My use case is that I’d like to capture tasks (using - [ ] my task) as part of the slide, but I don’t want this content to appear in either the speaker notes or in the slide.
This plugin is really a powerful tool.
Is it possible to install the real.js plugin in obsidian advanced slides?
For example, I want to use real.js Simplemenu plugin to automatically generate a table of contents bar at the top of the slideshow.
The plugins for reveal.js are here.
Thank you for your answer. I know advanced slides has Menu plugin, but I didn’t find Simplemenu plugin. I would like to automatically display chapters and highlight the current chapter on the slides, something like the following.
Yeah, now i remember, i tried to integrate simplemenu because i like the aesthetics, too but there was no easy way to automatically generate the Titles. Simplemenu wants a data field to be filled for menu generation which is not trivial.
The menu plugin generates the menu by looking into the slide and taking the first header it finds. Maybe there is an option that the developer of simplemenu would integrate such behavior?! Otherwise it would be to complicated to integrate it.
