Disable Spellcheck for hashtags (tags)
Ultimately, a cleaner editing screen and interface without hashtags showing underlines requiring a spellcheck.
My thinking is that it would be simple to detect a line of continuous text that starts with a hashtag ‘#’ and enable such a ‘word’ (or string) to be overlooked by spellchecking.
This could also be an Obsidian option for user to select either under ‘SpellCheck’ or under ‘Tags’ settings.
I’m not familiar with any possible work-around.
I found none.
I tried editing the post under ‘Current Workaround’ but there was an error when saving…
Current Workaround adendum:
I realise that each hashtag could probably be entered/added to a user dictionary and then not be highlighted for spellchecking, but this would quickly become tedious for continued use of numerous hashtags.
Such a manual intervention would interrupt the glorious workflow that is possible in Obsidian which I don’t think is consistent with the ethos of we are there to achieve and the tool that Obsidian is.
Honestly, I think any text that contains any non-alphabetical symbols shouldn’t be spell-checked. That’s how it is in most browsers, I believe.
It was lovely to see that Obsidian have now made this a standard feature!!!
Awesome :smiley:
