I’d like to have a plugin that would scan a DEVONthink 3 database and create a TOC for all the items in the subfolders. This would consist of the folders containing the item names with the DT3 links. To update a database, you would just run a new scan and create a new note whenever additions or deletions are made.
Am I dreaming or could this be done? Or has it been done and I missed it???
Thanks.
Did you try devon link plugin? Devonthink & Obsidian? - #10 by ryanjamurphy
Also there is another plugin in the making that can list files in the folder GitHub - akosbalasko/zoottelkeeper-obsidian-plugin
