Developer Console does not open - I had logstravaganza installed
I want to get rid of logstravaganza and after the deinstallation the developer console does NOT open.
This occurs in one of my vaults. The other vaults run fine but had never logstravaganza installed.
Restart of the whole obsidian instance. I looked auraund in .obsidianto find some traces but to no avail.
I solved it the hard way. I renamed the application directory in windows. Then I had to update again to 1.9.x, reconnect the sync and open all vaults.
You really should open an issue on the GitHub repository for logstravaganza so the developer is aware and can try to fix it.
