I’ve written an audio plugin for obsidian, renders an audio waveform in a custom code block, stop start buttons and region select for looping over sections. Now I’d like to add some keyboard control; space bar for play/pause, keys for setting loop markers, other keys for slow down/speed up. My best solution so far is custom keys but I’d rather be able to use single keystrokes without modifiers. So my question is, is there a way to detect specific keypresses in a custom code block, without those keys appearing in the containing note…
OK, so I have this so far. I had hoped that event.stopPropagation();
in the keypress handler would prevent the keypress putting a charactier into the note but it doesn’t.
Thoughts appreciated. thanks.
el.addEventListener("mouseover", () => {
console.log( "in" )
document.addEventListener("keydown", handleKeyPress);
el.addEventListener("mouseout", () => {
console.log( "out" )
document.removeEventListener("keydown", handleKeyPress);
function handleKeyPress(event) {
const keyPressed = event.key; // Get the specific key pressed
console.log(`Key "${keyPressed}" pressed while hovering over the element`);
I’d forgotten to add event.preventDefault();
. All working well now.
console.log( "in" )
