Hello everyone,
I am in search of a plugin that can enhance my ability to create detailed flowcharts. I’ve previously checked tools like Advanced Canvas and Mermaid, but now I need something a bit more different. Ideally, the plugin should have the following capabilities:
- Collapsible Nodes: The ability to expand or collapse nodes directly from each node, which can help in managing complex diagrams by showing detailed views only when needed.
 - Node-linked Pop-ups: Each node should be able to trigger a pop-up, ideally linking to a separate note or additional information that isn’t displayed directly on the diagram.
Thank you in advance for your help!
Best regards,
