Deleting a property from a base
Hi - if I create a new base, and I turn on a property and see that it has not been used in ANY of my records, is there a way to delete the property entirely? I can’t seem to find a way to do this…
Hello.
If a property is no longer used, you can select it in Show all Properties and choose Unassign type to remove it from the vault. That should also remove any trace of it in Bases. :crossed_fingers:
