When editing documents, I often need to delete entire sections under headings. Currently, this requires manually selecting all content under a heading and pressing backspace, which is time-consuming for lengthy sections.
- Add “Delete Section” option to heading right-click menu in editor and outline view.
- Alternative: Make Cmd/Ctrl+A first select everything under current heading, then on second press select entire document (current behavior).
Current workaround
Manually select all content under heading and press backspace.
