Backspace (on Windows) will delete an emoticon at one step
I need to do two strokes:
Before key press:
After first key press:
After next key press:
This is a codemirror bug. will be fixed once they fix it and we upgrade.
For reference, here’s the upstream bug: Backspace on emoji produces question mark character · Issue #6544 · codemirror/CodeMirror · GitHub
It was fixed/merged on 12/29/2020
@WhiteNoise is there somewhere we can track when this upgrade to CM is going to make its way to Obsidian?
Also, here’s a GIF I recorded earlier this morning, before I saw this bugreport, posting it here anyway…
should be fixed in 0.11.7
@WhiteNoise
Fix doesn’t work Obsidian 0.11.9 / Windows 10
This is emoji:
it works for me. Not sure if you have a very old installer version.
Example file Test.zip (232 Bytes)
There seems to be a problem only with that specific emoji and monospace fonts. You can file a bug report directly to codemirror.
It’s possible that tag is grapheme cluster and codemirror doesn’t handle those well.
