- In a new Vault, set Editor > “Default view for new tabs” to “Reading view”
- Enable the Daily notes core plugin.
- Open the daily note using the “Open today’s daily note” command.
Y
I expect the “Default view for new tabs” setting to be respected, resulting in my current daily note to be opened in reading view (even / especially when using the command rather than, e.g., through the files pane)
It obeys special (and I think undocumented?) behavior to always switch to editing view.
Operating system: ios 17.3.1 (Apple iPhone14,3)
Obsidian version: 1.5.8 (126)
API version: v1.5.8
Catalyst license: none
Live preview: off
Community theme: Things v2.1.20
Plugins installed: 10
Plugins enabled: 10
1: Attachment Management v0.9.6
2: Templater v2.2.3
3: Tag Wrangler v0.6.1
4: Dataview v0.5.64
5: QuickAdd v1.8.1
6: Style Settings v1.0.8
7: Default New Tab Page v0.11.4
8: Meta Bind v0.12.5
9: Hotkeys++ v0.2.7
10: Advanced Tables v0.21.0
The setting works as expected when opening notes, even the daily note, using other methods. However, the most convenient way to open the current daily note is using the command… so, effectively it is not possible to open the daily note in reading mode without giving up the normal UI affordances for opening it.
