Default embed does not work for new youtube links
NOTE: as a new user i can’t add more than 5 links, that’s why i added spaces on some of them.
Open or create a note, add Youtube links with the embed syntax “!()”.
If the url is “youtube.c om/watch?v=xxxxx” the embed works finde, but in some cases, youtube has started to add parameters to the querystring before the “v” parameter. I think obsidian does not look for that parameter containing the video id, instead it uses the first one.
Also, youtube now gives an option (it is official) to embed the video without cookies. This url is not recognized by obsidian.
Examples:
youtube.com/watch?v=zMaTrgUKC1w OK
youtube.com/watch?si=zda0Ly4zUzz2f8LJ&v=zMaTrgUKC1w tries to load “zda0Ly4zUzz2f8LJ” iframe works but the video is not found.
youtube-nocookie.com/watch?si=zda0Ly4zUzz2f8LJ&v=zMaTrgUKC1w Iframe does not work
youtube-nocookie.com/watch?v=zMaTrgUKC1w iframe does not work
Y
Those 4 videos should be shown on the iframe.
Also, as a nice to have, an option in settings to convert “youtube.c om” embeds to “youtube-nocookie.c om” as default.
Only the video with the first format worked well.
Operating system: ios 17.4 (Apple iPad13,1)
Obsidian version: 1.5.8 (126)
API version: v1.5.8
Catalyst license: none
IMG_0077
IMG_0078
IMG_0079
The si part we can handle better (even though I have never seen a url in that exact format).
You can open a FR for the youtube-nocookie.
If I paste this in Obsidian, I can play it within Obsidian
![](https://youtu.be/qjWq4ck2-0o)
If I use this link it will display, but clicking it will display an error
![]( https://www.youtube.com/watch?ab_channel=NicolevanderHoeven&v=qjWq4ck2-0o )
Omnivore and other capture apps pull different Youtube links depending on how you ended up on the page and more times than not those links result in the above error
Yes
I expect the video to be playable within Obsidian as the link is valid
It didn’t (see error above)
Obsidian version: v1.6.3
Installer version: v1.6.3
Operating system: Windows 10 Pro 10.0.26120
Plugins installed: 3
Plugins enabled: 3
1: Google Drive Sync v0.9.9-beta-11
2: Omnivore v1.10.3
3: Local REST API v2.4.3
Will be fixed 1.7
