DataviewJS TaskList without Header
For project notes I want to list all tasks with the status !.
let page = dv.current().file.tasks
dv.taskList(
    page
    .where(t => t.status === "!")
But this will give me the note name as a heading. I want it without the note name.
I tried to use groupByFile = false as by the reference
dv.taskList(
    page
    .where(t => t.status === "!"),
    groupByFile = false
But that results in an error
“Evaluation Error: ReferenceError: groupByFile is not defined”
I did find a solution (workarround), for showing another header, in dql. But I’m not sure how to dynamically select just the current note and I have not tried to grab the task status.
In DvJS tasks are grouped by default. You can use something like:
let page = dv.pages().file.tasks;
dv.taskList(
    page
    .where(t => t.status === "!").groupBy(p => p="Tasks")
But if you don’t want any header, then use DQL query:
TASK
WHERE status = "!"
Thanks for the quick response.
I was actually thinking of filtering the “tasks” and group them by status. I guess that would have done the trick :rofl:
Would you have any insides about the groupByFile option? I would love to update the reference. If not I’ll follow up on this on GitHub.
For the DQL solution:
How can I only narrow the scope to the current note? This should be dynamic solution. I know I could use templates at the creation. But if I change the file name/path, the query should still work.
That was actually the main reason I opted for DvJS.
  1. About the groupByFile I never tried (I’m more a dql user… and I’m not coder or similar). But I think you can use this format:
dv.taskList(
    page
    .where(t => t.status === "!"), false
  1. About DQL solution and defining only the current note, you can use this:
TASK
WHERE file.path = this.file.path
WHERE status = "!"
That was a fairly dumb mistake of mine.
Thx. I’ll update the documentation.
