I’m trying to create a basic table with dataviewjs on which I want to build upon.
const myTable = dv.el("table");
myTable.setAttribute("id", "myTable");
const headerRow = dv.el("tr");
headerRow.setAttribute("id", "headerRow");
const headerCell = dv.el("th");
headerCell.setAttribute("id", "headerCell");
headerCell.innerHTML = "Hello";
headerRow.appendChild(headerCell);
myTable.appendChild(headerRow);
const dataRow = dv.el("tr");
dataRow.setAttribute("id", "dataRow");
const dataCell = dv.el("th");
dataCell.setAttribute("id", "dataCell");
dataCell.innerHTML = "Hello again";
dataRow.appendChild(dataCell);
myTable.appendChild(dataRow);
With the above code I keep on getting random `- elements created in the DOM - any ideas as to why this is happening?
When you’re doing the dv.el("table"), you’re actually doing dv.el("table", "") but you’re omitting the text element, but dataviewjs will insert it either way, and that results in your empty span-elements.
So changing the syntax a little, and rearranging stuff to this:
```dataviewjs
const headerRow = dv.el("tr",
dv.el("th", "Hello", { attr: { id: "headerCell" } }),
{ attr: { id: "headerRow" } })
const myTable = dv.el("table", headerRow, { attr: { id: "myTable" } } )
const dataCell = dv.el("td", "Hello again", { attr: { id: "dataCell" } })
dataCell.innerText = "No span" /* Resets the inner text of the table cell */
const dataRow = dv.el("tr", dataCell, { attr: { id: "dataRow" } })
This gets me the HTML output of:
<div class="block-language-dataviewjs node-insert-event">
<table id="myTable">
<tr id="headerRow">
<th id="headerCell">
<span data-tag-name="p" class="el-p">Hello</span>
</th>
</tr>
<tr id="dataRow">
<td id="dataCell">No span</td>
</tr>
</table>
</div>
Note how using the dataCell.innerText we remove the span around that table cell also, which the previous alternative of doing the dv.el("th") doesn’t achieve. (So yes, the code is a little redundant, and the “Hello again” gets lost, so it could/should be removed again… )
Thanks! I’m no programmer so I went a little “creative” and threw this one everywhere
something.innerHTML = null;
system
Closed
June 6, 2023, 3:02pm
4
