I am using the following dataviewjs to show the most recent edited pages. The example where I saw this used shows that the page list is bulleted but mine is not. How can I make sure that this outputs a bulleted list?
Related with list output, what’s your output format? You mentioned the desired one, but you don’t say how it looks. It’s a list (one file per line) but without the bullet prefix?
The code is fine. Did you test the result in default theme? (themes can remove the dots/bullet). Did you test in reading mode? (reading mode is the definitive output mode, not the live preview… for example, inline queries have some issues in LP)
If the case I can’t help you more. I also have Minimal. It works in both: Minimal and default. (I’m still using the Obsidian public version, not the insider - 16 - with a new look).
Beside the themes you need to disable any snippet you use.
Your issue is css related, not a dataview specific issue.
You can always create a new vault, install only dataview and check the results.
