Hi, I was working on a dataviewjs table that shows me all websites (notes containing a special link) and the last time I checked them. As there is (at least to my knowledge) no feature to update a last-checked-date on clicking a url-link, I created a custom button to update a date (in my case a note property called modified)[Would probably make more sense to name it last-checked].
Each note containing a website looks e.g. like this:
# Note 1
url: https://help.obsidian.md/Home
created: 2024-07-17 12:38
modified: 2024-07-18 12:38
tag-links:
- "[[specialwebsite]]"
And my dataviewjs table looks like this:
// https://stackoverflow.com/questions/10830357/javascript-toisostring-ignores-timezone-offset
// offset in milliseconds
var tzoffset = (new Date()).getTimezoneOffset() * 60000;
var localISOTime = (new Date(Date.now() - tzoffset)).toISOString().slice(0, -5).replace("T", " ");
const now = moment()
dv.table(["Company", "Last Checked", "Update"], dv.pages('"MyFolder"')
.where(p => dv.func.contains(p["tag-links"], dv.func.link("specialwebsite")))
.map(p => [
p.file.link,
moment(p.file.mtime.toISO()).from(now),
// Next line doesn't work (probably because they're Strings?)
// localISOTime - p.file.mtime.toISO().slice(0, -10).replace("T", " "),
dv.el("span", "Update", {
cls: "edit-button",
onclick: async () => {
const file = await app.vault.getAbstractFileByPath(p.file.path);
if (file) {
const content = await app.vault.read(file);
const updatedContent = content.replace(/modified: .*/, `modified: ${localISOTime}`);
await app.vault.modify(file, updatedContent);
I’ve read that moment.js is kind of deprecated (Moment.js | Docs) and luxon should be preferred. However, I couldn’t get luxon running and really liked the function from() using moment.js as it beautifully prints the time difference.
As I also like to stay “minimal” I tried to find a way without using moment.js and luxon. Except for calculating and printing the time difference as elegant as with from() from moment.js it works fine (see comments).
Do you have any solutions or suggestions in general? What is the way to go?
