It works great, but is displaying each list item with two bullet icons:
Any idea why it’s doing that and how do I make it stop? I switched to a few different themes and they didn’t make a difference. I also tried moving the Ingredients folder to the root but it still shows two bullets.
That is the only change needed to get it working, but whilst working with this I reformatted the query, and personally I find it easier to read in this form:
I thinks this format is easier on the eye, and it’s easier to read what’s happening without all that side scrolling. But that’s a personal preference.
Bonus tip: How to present code properly in a forum post
If you want to showcase either markdown, or code blocks, or dataview queries properly in a forum post, be sure to add one line before and one life after what you want to present with four backticks, ````. This will ensure that any other backticks (like for code blocks) is properly shown.
Just tried your suggestion and it works perfectly. I do also prefer your suggested layout, helps me to better understand what’s going on and is more comparable to other languages I semi-know (I copy/pasted the code I was using from a forum post). I’m still early in learning this language! Thanks also for the tip on pasting code in the forum, I struggled with that!
