Hi,
maybe there is an expert in dataviewjs, who can help me.
As dataviewjs seems to be the only solution to apply a cssclass only for a section and not the entire note, I have this dataviewjs, that shows the correct results.
dataviewjs
const DQL = `
TABLE WITHOUT ID
"**"+ file.link + "**<br>" AS " ",
img AS " "
FROM "Reisen"
WHERE contains(status, "gebucht") OR contains(status, "geplant")
SORT startT ASC
dv.execute(DQL)
dv.container.classList.add("cards", "cards-1-1", "cards-cols-4")
When switching from code to preview or reading the table is shown for some seconds and then disappears forever although the code ist still correct and visible. If I alter the code the same thing happens again: the table is visible for some seconds and then gone.
This happens not onyl on the desktop but also on my mobile and tablet.
Try another dataviewjs
Disable all Snippets
Disable all other Plugins
Change from Minimal to Standard Theme.
Update Obsidian, Themes and Plugins
Reproduce it in the Sandbox Vault - the same error happens there
Check Inspector - no error message
Extensive search on the internet for a solution
Search for another way to apply cssclass only to a section
I would be very grateful if anyone could explain to me what I am doing wrong or have another solution for the partial attribution of a cssclass.
