Searching has not helped and I am hopeful that maybe there is something I am missing
I am relatively new to obsidian and enjoying it, the goal I have had is to create on the fly word count for the daily journal I have started. I wasn’t happy with the various plugins and have managed this instead by including the following in my template where I could reduce the total words by the template and its properties while outputting a property for dataview that it should be able to read in… in this case it does not but if I put in “[estWords2::678]” then it will work for estWords2.
the code I use that I found elsewhere and adjusted for me and my needs… basically it only calculates for the specific page I am within.
LIST WITHOUT ID "[estWords::" + estWords + "]"
WHERE file.name = this.file.name
FLATTEN regexreplace(file.path, "/?[^\/]+$", "") as parentFolder
FLATTEN length(file.name) as tcc
FLATTEN length(split(file.name, "[ _\.]")) as twc
FLATTEN round(0.95 * file.size - length(string(file.frontmatter))) as estChars
FLATTEN round(estChars / 5.1-132+46) as estWords
FLATTEN round(estWords / 300) as estPages
SORT file.size DESC
(note if you want to use this, just change the -132+46 to equal zero when you open a template)
this outputs in a dataview box:
- estWords: 678
and i think the “*” or the dataview box is the issue to be honest. so when I try to output it to a dataview table in another sheet, thinking I can gather some statistics and things on just how many adjusted words I am doing each day, etc… (yes, i am a data nerd… ) it comes out without the data / numbers., but like this:
File10 | dateformat(file.mtime, “yyyy.MM.dd - HH:mm”) | Last modified |
2024-10-18 | 2024.10.18 - 15:04 | * estWords + |
2024-10-17 | 2024.10.18 - 08:42 | * estWords + |
you see it does not output the number but “* estWords +” … seems something in the parser gets stuck in this case., Here is the code I am using:
TABLE dateformat(file.mtime, "yyyy.MM.dd - HH:mm"), estWords
AS "Last modified"
FROM "_personal/Daily Journals"
WHERE estWords > 0
SORT file.ctime
DESC LIMIT 10
if i should use the text as I input it manually eg i type in the text “[estWords2::678]” then it will pick it up:
then the output is:
File1 | dateformat(file.mtime, yyyy.MM.dd - HH:mm) | Last modified |
2024-10-18 | 2024.10.18 - 15:04 | 678 |
notice today i had 678
… Maybe using the inline JS would work (?) but it seemed a bit more complex than the dataview as I am using it now. … but if anyone knows how to convert it I would appreciate it.
