Dataview: Use frontmatter field as alias even though it's not called "alias"?
I have a table of cool words that I’m collecting in a vault called “Dictionary”. One field of the frontmatter is called “Entry”. Is it possible to tell dataview when linking to this note from another one that it should use “Entry” as the alias even though it’s not called “alias”?
so the field “Entry” is meant to act the same as “alias”.
Thanks!
Dataview is not on charge of generating links, that is Obsidian itself. And to my knowledge it’s not able to pick up aliases from other fields, and I’m not aware of if other plugins (and if so, which) are able to do so.
Ah OK, that’s good to know, thanks :slight_smile:
