Dataview to Bases conversion for links
I want to translate this dataview code into the new bases syntax
table WITHOUT ID file.link AS "Note", length(file.inlinks) * 4 + length(file.outlinks) as "Total", length(file.inlinks) as "In", length(file.outlinks) as "Out"
from ""
where length(file.inlinks) * 4 + length(file.outlinks) > 0
sort length(file.inlinks) * 4 + length(file.outlinks) desc
limit 25
This code gives me the top 25 notes which have the highest total link score.
Whereas the total link score = sum of inlinks * 4 + sum of outlinks.
So basically it displays the top 25 notes with the most in- and outlinks.
Using the list.length() function in conjuction with file.backlinks and file.links.
  • list.length(file.backlinks) :cross_mark:
  • list.length(file.links) :cross_mark:
In both cases no value is displayed inside the base.
Using just file.backlinks and file.links works, but only provides me with a combined list.
  • file.backlinks :check_mark:
  • file.links :check_mark:
  • file.backlinks + file.links :check_mark:
Yet, what I want is the number (length) of links and backlinks (aka outlinks and inlinks).
Something like:
  • list.length(file.backlinks) * 4 + list.length(file.links)
Maybe the problem is that the list.length() function only works with an ordered list of elements such as [1, 2, 3] according to the offical documentation. What file.backlinks and file.links gives me is an unordered list (I would assume).
Somebody has any idea how to approach this?
Okay, I got it.
file.links.length + file.backlinks.length * 4
