Hello,
I am using the dataview plugin with the following query
table rows.file.link as Database, area as Area
from #database
group by area
sort area asc
Here is the YAML header of one of the file :
area: Lecture
#database
but here is the display, I do not understand, the lines without area, these are duplicated lines as all have area
Hello,
from #database
group by area
sort area asc
area: Lecture
#database
@szdavid: You’re crossposting (asking the same question multiple times in different places), which is not too well received in many forums. See Dataview, strange display.
Short answer: The output is perfectly alright: You asked for area grouping and got it (right column). One Group “-”, one group “Databases”, one group “Lecture”. The elements of these groups are shown in the left column.
Thank you @Moonbase59 ; Ok for Lecture and Databases but the - one, I do not know where it comes from… not defined in my yaml
It will do that for all cases where it doesn’t see area:, just tried to verify. So you should check if, say “Prochains livres” actually contains an area: in the front matter (maybe not there, typo, empty or wrong data type).
