```dataview
LIST list-field
FROM #f54644
WHERE list-field
SORT list-field desc
LIMIT 4
SORT list-field asc
LIMIT 3
Given that you want N entries, and remove M entries, then reverse sort and limit to M + N entries, and then sort again, and limit to N entries. This does require you know the number of entries available, and are able to select a lower number for N to use.
Not sure how to do this if the number of entries are unknown, or possibly less than N.
Dataviewjs with sliceing
Another safer option would be to repeat the query using const result = dv.query() within dataviewjs, and then just slice of the first entries, before presenting the result.
```dataviewjs
const keepElements = 3
const skipElements = 1
const result = await dv.query(`
LIST list-field
FROM #f54644
WHERE list-field
SORT list-field
LIMIT ${ keepElements + skipElements }
`) // Remember to increase the limit by the number of skipped entries
if ( result.successful ) {
const values = result.value.values.slice(skipElements)
dv.list(values)
} else
dv.paragraph("~~~~\n" + result.error + "\n~~~~")
Workflow to use this:
Copy your query into the DQL query part at the top
Change the two constants to match how many items to keep, and how many to skip
If you want, you can also do them as constants in the LIMIT ... statement, and .slice( ... ) statement.
