I want to query data found in a field, but the source is not a tag, nor a link, nor a field proper. so its a field that contain links, and from those links I want their FieldB info.
is it possible?
its a simple roll-up found in Airtable
I know its very basic but I still have trouble with this
thank you so much !!!
I have some difficulty to understand (Tengo alguna dificultad para entender la relación de los dos campos)
You don’t have two different fields: FieldA and FieldB are the same > «Funcionalidad». Same field in different notes (with specific values/data).
FieldA is = Farmaco
FIeld B is = Funcionalidad (a Field only found in Farmaco)
Field C (the query) is Funcionalidad or any other name, if this isnt appropiate
You have:
- field(name) :: value
If you use the same field(name) in multiple notes/files, then the field is the same.
So, it’s advised change the name for the query field.
I still don’t understand well the desired query. But, for this example, you can try this:
MyQueryName:: `=this.Farmaco.Funcionalidad`
excellent!!!
thank you
