Bonjour à tous - Hello everyone !
My notes have metadatas called “Domaine” and “Sous-Domaine”. I want to get a TABLE in Dataview that lists the Domaines in a first column, and in a second column the Sous-Domaines attached to each Domaine.
I almost passed this task with:
TABLE rows.Sous-Domaine AS Sous-Domaine FROM "MD intégrées" WHERE Domaine OR Sous-Domaine GROUP BY Domaine
Problem :
With this method, in the Sous-Domaine column, each value is displayed as many times as it exists in my notes (if I have 58 notes with the value “Programmation” in the key “Sous-Domaine”, my TABLE will display 58 lines “Pogrammation”).
I only want one per value.
Is this possible and if so how? Is it necessary to go use a dataviewJS query ?
Thank you for your help
