For what reason meta from this.file.inlinks and this.file.frontmatter.myproperty are displayed as links in both cases, but can’t metadata be extracted from myproperty in the same way as inlinks?
Case:
Where did the “string” come from if it is displayed in the table as a full-fledged link?! What about the error text?
Code
TABLE WITHOUT ID
map(this.file.frontmatter.children, (x) => x) AS tmp,
map(this.file.inlinks, (x) => x) AS tmp2
WHERE file.name = this.file.name
- Please fix it
- Since the repair will be long (and it’s not a fact that it will be fixed - developers may be refer to some useless “philosophy” - I’ve seen it often) soooo - how do I extract similar metadata from myproperty, as well as from inlinks, in the current conditions?
