You seem to have typos in your post so it’s not very clear what you actually use for the date in your selection. Like what do you mean with date = (today), are you trying to compare against a date property? Or are you just missing to write date(today)? Or should there be something like file.mtime?
Then again the result you’re presenting says “2024-38-06-08:38”. Is this supposed to be a date? Which format is that? It’s not ISO 8601, at least.
Finally, if you’re using file.mtime you should either switch to file.mday or striptime(file.mtime) to get rid of the timestamp from your full date. And you might need to do file.mday.ts and date(today).ts when comparing for equality.
Helpful tip about removing the timestamp — I didn’t know how to do that:
I did show some alternatives I was trying on the journey.
That was my question! I couldn’t work this out, nor understand why each ‘date’ was the same. Hoping someone with familiarity with Dataview and iots ways, can point to an answer.
Blockquote You seem to have typos in your post so it’s not very clear what you actually use for the date in your selection. Like what do you mean with date = (today), are you trying to compare against a date property? Or are you just missing to write date(today)? Or should there be something like file.mtime?
Yes, trying to compare against a date property (as “What I’m trying to do”, above)
It should be a date and I would expect a date. The format is a mystery. And also why every entry is the same. As already stated, this is the essence of my question.
I have already commented, with thanks, for this suggestion
