Hi, again.
Two things:
- If you use literally this format, you donāt have any field:
If you want to use the full-inline format (key:: value) you canāt add text before your field. You can use this format:
10:55
maintain:: Some Task
or
11:17
- maintain2:: Some Other Task
If you want to keep all the content in the same line, then you need to use the inline field in the format [key:: value] or (key:: value) (the difference in the brackets is related to the render of the field - you need to enable the inline field highlighting in settings > dataview - round brackets hides the key):
10:55 - (maintain:: Some Task)
11:17 - (maintain2:: Some Other Task)
- About the query, I have some difficult to understand your goal⦠If you want a list of āmaintainā values in each note, why you give two different key names? Why you donāt use the follow format (multiple values for same key)?
11:17 - (maintain:: Some Other Task)
If you want to join two fields in same column you can work with list(maintain, maintain2) AS "Tasks"⦠but youāll have issues when one of the values is empty; or if you want the output as a string (and not a list), you can use default(maintain, "") + ", " + default(maintain2, "") AS Tasks; or ā¦
