Dark/light mode switching with system mode switching
Hi,
First, I am on CachyOS using KDE. Whenever I toggle light and dark mode system settings, Obsidian reflects the opposite mode.
# set system to light mode
# set Obsidian to light mode
# switch system theme to dark mode
Observed the opposite mode change in Obsidian's theme
# the toggle for system theme switching is enabled in settings. (hopefully
# this answers the first forum response :)
Troubleshooting guide:
  1. I am on package 1.12.4-1 which is [installed] on my distribution.
  2. I have disabled Syncthings for both directories, when that didn’t resolve it, I deleted the directory from Syncthings, re-scanned using Syncthings and it still did not resolve the issue.
  3. I have no community themes installed.
  4. Restart after the above changes had no effect.
  5. Theme switching appears TO WORK, however THE COLORS ARE REVERSED. I.e. system mode on light, Obsidian is dark, system mode on dark, Obsidian is light. Also, it did not switch on the first attempt.
THERE ARE NO COMMUNITY PLUGINs INSTALLED
# expected behavior
On the switch of the system mode, the colors in the application should switch, to the corresponding mode.
# actual behavior
Opposite system vs. Obsidian theme
# logs
	Obsidian version: 1.12.4
	Installer version: 1.12.4
	Operating system: #1 SMP PREEMPT_DYNAMIC Thu, 12 Mar 2026 17:29:21 +0000 6.18.17-1-cachyos-hardened
	Catalyst license: none
