Daily note does not expand {{date}} when creating template
This is Obsidian 0.8.15. When I create a daily note with “Open today’s note”, the current note is created, but the template is not properly expanded.
If I delete the contents and insert the same template, all is well:
The Daily Notes plugin does not use the default {{date}} token from the Templates plugin. You need to specify the format.
This will work -> {{date:YY-MM-DD}}
Oh. It is possible. I’m deleting my previous reply, then. Sorry about that, guys.
¯_(ツ)_/¯
