I use the Daily Notes as a home base to record fleeting notes throughout the day.
For example,
23-01-2020
[[First Topic]]
Some text about the first topic.
[[Second Topic]]
Some text about the second topic.
By using the Note Refactor plugin I then append whatever I write below a wiki-linked topic to that very same note.
To do this I first highlight the wikilink heading, hit Ctrl + Shift + C , then select the file to append or create.
This results in the following:
When I come back to that same topic in the future I can do the same thing from another Daily Note page. Eventually this builds up and I can write more permanent content on the topic note. Although I could just look in the backlinks panel, this allows me to see everything on one page and easily toggle on or off.
It is particularly useful when taking notes in meetings or just generally ‘thinking out loud’ all day. Until I found this workflow I was on the fence about using an additional outliner tool (e.g. Logseq, Roam, etc.) but now I can quite confidently say I’m “all in” on Obsidian.
It took me a while to figure out how the templates should be configured in the Note Refactor plugin so I thought I would share that here.
“Note link template”:
[[{{new_note_title}}]]
“Refactored note template”:
### {{title}}
![[{{title}}#{{new_note_title}}]]
Anyway, big thanks to James Lynch for creating this plugin, it has revolutionized the way I use Obsidian.
