Thanks!
I must be one of the crazy ones. Hands down my favorite theme. Definitely beautiful and inspiring.
Love how this theme looks.
I wonder if it makes sense to still have Andy mode built into the CSS here since that can be handled by the sliding panes plugin. Seems a bit of unnecessary duplication and I personally like to toggle Andy mode on and off.
Crazy like a fox! Happy to hear. Yeah, it should be offensive to my sensesâI would thinkâbut instead I want to lick the screen
I agree. I need to spend a concentrated and careful moment to decouple to old CSS from my theme to make sure nothing funky is affected
Thanks for sharing this theme, I really like it! One thing Iâm having trouble with is whenever I indent underneath a heading, the text formatting gets changed (see screenshot). Is there a way I can modify the theme to keep the normal formatting? Thanks!
My best guess: Go to Settings > Editor > Tab size
and reduce the tab size.
Mine is set to 4 spaces and I donât get the problem youâre having. Good luck!
Hmm, even setting it to 4 I still have this problem. I guess it might have to do with some of the CSS modifications I made to the theme. Thanks anyway!
Hmm, sorry I couldnât help more
This is core markdown behavior. Indenting results in a psuedo-codeblock element. Thereâs not really a way around it as far as Iâm aware.
Hey Nick, you can see in the left panel, no icons are visible except the recent files icon. Could you try to fix thisâ„
Thanks Jayant. So thatâs not the behavior Iâm getting.
My only idea is to make sure âApply custom CSSâ is toggled off.
But itâs on and in light mode I see thisâŠ
notice how only the recent files icon is greyed while others are totally black
and turning âApply Custom Cssâ on or off doesnât make any difference
You shouldnât have to do that to âfixâ it though. Hereâs I found the CSS stuff that you can you to manually put in at the bottom of the CSS file:
.workspace-tab-header-inner-icon {
color: #fcf601
.workspace-tab-header-inner-icon:hover {
color: #3DD87F
Note: Change the colors to your liking of course!
Thatâs a short-term fix for you. I will probably tinker with the main version soon.
Hey, I just spent some time tweaking Cybertron, so make sure to reload it in the Community Themesâhit Cmd-r
tooâand hopefully the changes take effect!
Hey Nick, I think this invisible button is specific to my pc only as no one else seems to get this. Anyways I love the theme and appreciate your efforts for fixing this, but I think I like the fix I made and you donât have to waste time on this anymore.
I just want to know one more thing, the internal links are coloured brown and I find it difficult to see them in preview mode, can you tell me how to change the colour of the internal links
They should be pink. You mean the [[bracketed]] links?
yup the [[bracketed]] links, how can I change the colour?
