I open multiple vaults with Obsidian on the same computer. When I look at these running instances of Obsidian in the taskbar, it’s difficult to tell them apart, especially since the (usually long) name of the current note appears before the vault name.
If I could set a different taskbar icon per vault, it’ll be very easy and convenient for me to visually understand which vault is open in which instance.
There is the Accent Color option in Appearance section of Obsidian Settings. It would be nice, if this Color used to Obsidian icon in all places, where it appears, including taskbar. (Let the icon itself remain the same, only its color changes).
Since Accent Color is per-vault setting, this will satisfy your request.
I tried the Accent Color now and it’s nice, thank you. I do still want the taskbar color to change as well, either according to that accent color or by setting a custom icon.
Yes, this would be highly useful when you have multiple vaults open. The “Accent Color option in Appearance section” (@Andr) does NOT change anything in the taskbar for me.
Different icons would be optimal, but a maybe easier to implement change would be to have an option to display the vault name first in the taskbar instead of the current note’s name.
I have the same request. It is very handy that a separate icon for each vault on the taskbar when using multiple vaults concurrently.
So, I created utility tools as a workaround for this topic until officially implement this feature. A little bit unshapely, but works for me as a workaround.
Wow, cool, thank you very much! This works for all apps, right? That is more than a workaround. This is very handy to have in the toolbox for Windows for all apps.
Yes, the mechanism of this tool works with all apps if you have identified the target window title or the process ID of the target window belongs to. But I tested with Obsidian and VS Code only.
Essentially, the window grouping is managed by the app itself (AppUserModelIDs managed by the app itself). This tool change it from externally, so, that is unorthodox way.
Thanks a lot for the tool!
I’d just like to add that if anyone is unsure about what to use as icons for different vaults, Obsidian has provided a way to quickly customize the icon by changing its color at the bottom of this page, which allows you to quickly grab a set of different colored Obsidian icons for each of your vaults.
+1 for this feature. Natively having a separate taskbar icon per vault would be amazing (it seems to only happen for some people as a sort of bug). Changing the icon/icon colour of each icon of course would be really nice.
I’m extremely interested in this feature and have been trying to find a workaround for a while. Obsidian has become my tool of choice across a wide arrange of topics and uses.
For example, I have a programming notebook, mathematics notbook, project management notebook and so on. Being able to distinguish different app icons in the taskbar would be a real boost for me.
How do we vote on feature requests? Jetbrains and I believe Atlassian allow you to do this. Would be awesome to do the same here.
I came here looking for the same thing. It’s a huge point of friction to identify which vault I’m looking for when I go to the Obsidian icon to open a specific vault. I’m working with 4 vaults now.
I would like this feature too. I have a study vault with my notes and I have a personal life vault I want open at the same time. I would prefer a way to customise individual vault icons on the taskbar.
Each ribbon is a different color. If I see the reddish ribbon I’m in my research vault, a blueish ribbon my personal vault, and a greenish ribbon my publish vault.
So I always know which vault I’m in by looking at the ribbon color.
Necroposting but I made a plugin that lets you add Windows overlays/badges based on the vault you’re in. It’s a little finnicky but it works for me and solved a problem that was really annoying me. I can’t add links but it’s called “Vault Badge.”
