I was trying this the other day and it wasn’t working so gave up.
After some spelunking with the Discord gang, it looks like the v1.4.5 installer (Electron version?) broke something. The v1.3.7 installer seems alright.
So custom-svg callouts are broken in the current v1.4.13? Thanks for mentioning this here! I just sat for over an hour trying to figure out what I was doing wrong
To revert to v1.3.7, can I just install it over the newer version or will that just mess things up more?
@Cricket742 - Apologies, I missed your follow-up.
Usually custom CSS isn’t considered for bug reports, but as this method is detailed in the help documentation and not working at the moment, I think so.
@tophee You need to turn off auto-updates, but installing the old installer over the new one should be fine. I’d make a backup of my vault(s) for good measure.
I’ve managed to get this working on Obsidian version: v1.4.14, Installer version: v1.3.5 by updating my snippet. Not pretty, but is easier than downgrading (imho).
