ironhak
1
Hi everyone, I create this simple snippet:
.callout[data-callout=“hello”] {
–callout-color: 255,215,0;
–callout-icon: lucide-highlighter;
It should generate a yellow callout, but the result is this:
I tried restarting the app and changing themes but nothing change. What am I doing wrong?
Also I would like to know if i can create a callout without an icon.
Thank’s for your help.
mnvwvnm
2
Maybe something like:
.callout[data-callout="hello"] {
--callout-color: 255,215,0;
--callout-icon: highlight-glyph;
For a callout without icon, for example the callout “none”
.callout[data-callout="none"] {
.callout[data-callout="none"] .callout-icon {
display: none;
I created a .css file, added to snippet folder and enabled it on obsidian, this is the snippet:
–callout-icon: highlight-glyph;
.callout[data-callout=“none”] {
.callout[data-callout=“none”] .callout-icon {
display: none;
Then I went to obsidian and typed this:
[!hello] hhh
kjjh
[!none] ukhkh
khlk
Result is:
Even tried reloading the app, nothing change. What am I doing wrong?
Attention to the used quotation marks. use straight (") marks, not curly (”).
Also --
not -
My bad, I was using textedit and then changing the extension of the file without realising that text get corrupted.
Thank’s.
system
Closed
6
