In RTL notes that has text block exceeds 1500 words, the cursor movement becomes erratic. Pressing the right arrow key causes the cursor to move to the left, and vice versa. However, inserting a line break or return character in the text block restores the cursor’s normal movement.
i tried using sandbox vault.
i expect the cursor movement to be consistent. right arrow makes the cursor moves to the right, and left arrow makes cursor moves to the left
the cursor movement is erratic. Pressing the right arrow key causes the cursor to move to the left, and vice versa
Obsidian version: v1.8.10
Installer version: v1.6.7
Operating system: Darwin Kernel Version 24.4.0: Wed Mar 19 21:12:54 PDT 2025; root:xnu-11417.101.15~1/RELEASE_ARM64_T8103 24.4.0
Catalyst license: insider
Inserting a line break or return character in the text block restores the cursor’s normal movement.
