Greetings. I am new and seem to be having the same problem. I do not have the Calendar app installed, but I have noticed that when I go into reading mode, I can do CTRL+A and select all the text, but as soon as I initiate the CTRL+C command, it deselects all the text and nothing is copied. Here’s my debug info if that helps:
Obsidian version: v1.5.3
Installer version: v1.4.16
Catalyst license: none
Community theme: LYT Mode v1.9.1
Plugins installed: 13
Plugins enabled: 11
1: Google Keep Import v1.1.3
2: Importer v1.5.6
3: Zotero Integration v3.1.7
4: Tag Wrangler v0.6.1
5: Core Search Assistant v0.9.2
6: Quick Explorer v0.2.8
7: File Explorer Note Count v1.2.1
8: Kindle Highlights v1.9.2
9: Filename Heading Sync v1.9.0
10: Omnisearch v1.21.1
11: Extract Highlights v0.0.18
I think I find a workaround. In preview, cmd+a selects not only all the contents but also the file name (under the tab bar), which stops cmd+c from working. Manually select from the start to the end of the file and cmd+c now works as expected.
This is a great workaround! But… we should fix what Ctrl + A (or Cmd + A) does to default to selecting all of the content text so that you can then copy it with keyboard.
There is a workaround for this, go to settings | appearance and disable “show tab title bar”. This prevents ctrl + a from selecting text in the title bar and ctrl + c works as expected.
If you like having the breadcrumb, you can use “quick explorer” plugin to have a breadcrumb in the bottom statusbar instead
EDIT: Getting Ctrl + A working reveals another bug though… If you have a really long note, selecting with ctrl + a and then copying doesn’t always copy all of the text.. you have to scroll to the bottom of the note before hitting ctrl + c to get it to copy all of the text
