Css snippets not supported in android device
Please help guys
A lot more detail is needed here if you’d like anyone to help.
So I wanted to use css in my workflow to make it sort of unique by changing notebook color and text color etc
I am using an android phone that too a latest one. But when I tried to install the css snippets from the community plugins it showed that " plugin doesn’t support your device " so then Manually tried to install it then it did got installed but didn’t enable , I tried to create an snippets folder in .obsedian file and added some css text files from GitHub but when I executed them they just didn’t work. No css commands were taken action upon as if the css commands weren’t even recognised.
Please help guy
Some community plugins use CSS to change the look of things, but CSS snippets aren’t typically installed via community plugins. Have a look here:
Also, if you link to the CSS you are trying to install, maybe someone can give a few pointers on installation, usage, check if it works on mobile, etc.
Also, I forgot to mention that this is a great plugin for adding and editing snippets, especially if you are mobile only:
I can’t do as it’s been told in this video.
The command just doesn’t work.
