Cross-platform secure storage for secrets and tokens that can be sync'd
Currently, it’s not safe to store secrets or credentials in Obsidian in a cross-platform safe way. In terms of integrations with outside services.
On the desktop we can use the Electron or Node.js APIs to keep things partially secure. Using the Electron safeStorage API means I can encrypt and decrypt my data using my own mechanisms and I don’t need to worry about key storage since this is delegated to the OS (KeyChain on Mac, Windows credentials stores and whatever credentials store is installed by the window manager on Linux).
On mobile there is no such API that I’m aware of?
I would propose that Obsidian API include some mechanisms that can be used cross-platform to allow for the encryption and decryption of data.
My suggestion would be to emulate the electron safeStorage API. This would allow plugin developers to use a safe encryption/decryption scheme that is safe across mobile and desktop.
The key management and sync could then be managed safely by Obsidian in the background.
While working with a plugin designed to sync vaults to version control and potentially share them publicly, I noticed some plugins store sensitive data, like API keys, in the .obsidian folder, either as standalone files or inside the plugin’s data.json. It’s possible (if generally unlikely) for users to unwittingly share this information.
If there were a standard location for plugin developers to store secrets and sensitive information, e.g., a .secrets folder, that would allow users (and plugins) to safely share non-sensitive information while being more guarded with sensitive data.
Plugins could set a flag in their manifest declaring that they use the .secrets folder, and a standard notice could be displayed. Other plugins could use the manifest list (along with a standard location) to perform automated audits, encrypt/decrypt secrets files on the fly, etc.
Hello everyone,
I am working on the Google calendar plugin and have encountered the problem of storing the access and refresh API token as well as the custom client ID and secret inside obsidian. I have postponed this issue long enough by storing the data inside the local storage of obsidian. My problem is, that everyone has access to this storage.
I looked into using electrons saveStorage or third party libraries using the system keychain to encrypt the data, but came to the conclusion that this doesn’t add any additional security, plus it is not compatible for mobile users.
My Idea would be to add an option inside the settings to password protect the confidential data using AES. The drawback would be to enter the password every time obsidian starts.
I would like your opinion and insides on this idea. Would you use such an option, if it increases security? Would this add security?
I would like to implement OAuth login for Imgur plugin. And it will need to store tokens somewhere. Plugin settings is obviously not an option, because it stores data in plain text inside of a vault. In Discord chat I was suggested to try LocalStorage, but with a caution that it won’t probably work in mobile version. While Imgur plugin does not target mobile platform, what is the most preferable place to store sensitive data? And if there is no such a place, it’s probably worth thinking about creating such an API for plugins.
Quoting snyk.io:
local storage should never be used for sensitive information such as passwords or personal information
PS One other thing which prevents me from implementing OAuth login is that I can not receive all the data coming to Obsidian protocol handler as part of a callback URL, see the detailed description here
Did you ever find a good workaround?
Nope, I did not try to find anything (now I am stuck with OAuth authentication implementation, I do not even have secrets to store yet). But as soon as I will be able to proceed I would stick with localstorage until there is no better API for secrets. I think for me localstorage is a good fit (Imgur authentication can be shared between multiple vaults, and I do not worry about mobile support since I am not targeting it)
A couple of thoughts I had recently on this topic:
  • I do not think localstorage is a good fit for sensitive data, because it gets shared between any other plugin, and some evil plugin could dump Object.entries(localStorage) and steal your secrets (if they will be stored there).
  • On the other hand I like that localstorage data is available between Vaults. For my Imgur plugin it means that once authenticated in one Vault, you do not need to repeat this step for any other Vault.
Summarizing: localStorage is not an option for really sensitive data. I would like to have some interface for Obsidian which would isolate secret data of different plugins from each other, allowing to share such data for the same plugin between vaults on a single system.
Hi there, I’m wondering if anyone found a save place to store sensitive information? I do not have requirements of sharing these across other vaults). However, mobile support is required, the user simply has to enter these information for each vault / device again. Otherwise, I’m tempted to manage the encryption my self but it would be overhead, for a common problem I suppose
Can you store the token somewhere online? There are plenty of free services where you can bring up a simple server of a few lines written in Python or Go which will return that token on demand. After authentication of course. Let’s Encrypt will provide a secure connection.
That way you won’t care about which platform you are using.
I know it is a bit complicated but can’t think about anything else.
Kinda. I’ve partially written a plugin for developers that exposes an API to handle safe secret handling.
I’m using non-exportable keys and relying on the WebCrypto API standard to protect the keys in-flight.
  • Each device gets it’s own non-extractable $TBD_Key_Algo (signing) and $TBD_Key_Ex_ALGO (key exchange) key pairs.
  • Each Vault has a Vault Root Key (VRK) used to wrap per-file DEKs.
  • Each Plugin operates in it’s own key space which is derived from the VRF with a HKDF.
I’m currently a little stuck. The $TBD_Key_Algo and $TBD_Key_Ex_ALGO I want to use are Ed25519 and X25519. I could pivot to ECDSA and and ECDH and that’s what I’m currently looking into, with a progression plan to allow the user to migrate to new key algorithms.
ECDSA and ECDH isn’t the best option… and RSA is… 48 years old and I’m loathe to go anywhere near key generation and crypto functions on mobile devices where the keys are getting progressively longer (recommendation these days is for 3072bit keys)…
The current API looks like this:
const shard = app.plugins.getPlugin("obsidian-shard")?.api;
// 1. Request a scoped capability
const cap = await shard.requestCapability("my.plugin.id", { ops: ["seal","open"], ttlSec: 120 });
// 2. Ensure a vault and local identity exist
const meta = await shard.Vault.ensureVault();
// 3. Encrypt (seal) data
const plaintext = new TextEncoder().encode("Secret data");
const sealed = await shard.Crypto.seal(meta.vaultId, plaintext, undefined, cap, "my.plugin.id", "encryptedfile.bin");
// 4. Decrypt (open) data
const opened = await shard.Crypto.open(meta.vaultId, sealed, undefined, cap, "my.plugin.id", "encryptedfile.bin");
Using per-plugin encryption domains will reduce the blast radius of implementing crypto in an inconsistent way.
Here’s my current TODO list for release:
  • UI for settings and encrypted data management.
  • SPAKE2-P256 VRK recovery implementation - WebCrypto APIs don’t support it.
  • Device authorisation flows - each device will need to be authorised to access the encrypted data.
  • Looooooottttsssss of testing.
The last thing I want to do is push this out, half-finished and others pick it up and encrypt users data irretrievably while I’m fiddling with the API.
~ R
This is being worked on in V1.11.
@WhiteNoise I see in the 1.11.4 catalyst release you provide a new api
API: Exposed new SecretStorage and a complementary SecretComponent for plugins to integrate with the secret storage.
Where do you actually store those secret when running Linux? Do you use the chromium/electron API’s - meaning I can change the used storage with the --password-store flag (like --password-store=gnome-libsecret). Actually it’s called safeStorage in electron safeStorage | Electron.
Thanks!
Looking at DevTools on the public 1.11.4 release, secrets appear to be stored in LocalStorage. There are a couple relevant mentions in app.js, and a test secret I created was stored in a JSON object under {vault ID}-secrets. Secrets also don’t sync between devices, it didn’t appear on my phone.
Just a heads-up that the new SecretStorage API (v1.11.4) currently stores credentials in plain text in Local Storage, meaning they are not yet encrypted at rest and can be dumped by other processes. I’ve opened a bug report with a PoC showing how these secrets can be leaked.
  1. Use the SecretStorage API (introduced in v1.11.4) to store a sensitive credential (e.g., an API Key) within a plugin.
  2. Close Obsidian to ensure the database files can be accessed by external scripts.
  3. Run the following Node.js script (PoC) targeting the Obsidian local storage directory:
import { Level } from 'npm:level';
// Path example for macOS; adjust for Windows/Linux accordingly
const dbPath = '/Users/<YOUR_USER>/Library/Application Support/obsidian/Local Storage/leveldb';
const db = new Level(dbPath);
async function readSecrets() {
  for await (const [key, value] of db.iterator()) {
    if (key.endsWith('-secrets')) {
      console.log('UNENCRYPTED SECRET FOUND:');
      console.log(`Key: ${key}`);
      console.log(`Value: ${value}`);
      console.log('---');
await readSecrets();
Y
Secrets stored via the SecretStorage API should be encrypted at rest using OS-level secure storage (e.g., electron.safeStorage on Desktop or capacitor-secure-storage-plugin on Mobile) to ensure credentials are not human-readable.
The PoC script successfully retrieves and prints the secrets in plain-text JSON format. The data is stored without any encryption layer, making it accessible to any process with read permissions to the user’s application data folder.
	Obsidian version: v1.11.4
	Installer version: v1.11.4
	Operating system: Darwin Kernel Version 24.6.0: Mon Aug 11 21:15:09 PDT 2025; root:xnu-11417.140.69.701.11~1/RELEASE_ARM64_T6041 24.6.0
Security Risk & Observations:
  • Live Leakage via WAL Scan: Even when Obsidian is running and the database is “locked,” secrets can still be leaked by scanning the Write-Ahead Logging (WAL) journals (.log files). This can be reproduced by running a string scan or using leveldbutil while the app is active:
# Run this while Obsidian is open to see live secret commits in the WAL
cd "/Users/<USER>/Library/Application Support/obsidian/Local Storage/leveldb"
leveldbutil dump *.ldb 000096.log 2>&1 | grep -i "-secrets"
Proposed Mitigation:
  • Encryption at Rest: Implement electron.safeStorage for Desktop to encrypt secret records before they are saved to LevelDB.
  • Secure Mobile Storage: Use native secure storage APIs for mobile platforms.
Security Notice Recommendation
A separate notice should be issued regarding cookieEncryption fuses, specifically for the Web Viewer plugin. Cookies may currently be at risk of leaking. Users should be advised to update their installer to v1.11.4 (rather than just an in-app update) to ensure these security features and Electron fuses are correctly initialized and active.
I will migrate the data to electron safeStorage in the next update.
@Licat So you say you want to move all secrets over to the safeStore 1by1? Or do you plan to store an encryption key and use that key to encrypt each secret and keep them stored (encrypted) in Local Store. IMHO the second approach is the way to go. This how Signal does it, and also this is how chromium (the browser, not electron) does it. All you need to do is to set an encryption key via safeStorage.setUsePlainTextEncryption(usePlainText) then you can safeStorage.encryptString(plainText) and decrypt it again with safeStorage.decryptString(encrypted).
See the docs here: safeStorage | Electron
And another important thing: cookies were mentioned above. Please aso encrypt cookies the same way. chromium is doing that as well.
Thanks!
Allow me to add:
The approach of just storing an encryption key also makes Obsidian more portable, because it’s easier to move the Obsidion folder over to another machine. Because on the new machine users just need to store the encryption key.
E.g. when using the Secret Service API in Linux (forcing via --password-store=gnome-libsecret if not default on the plattform) you need to store the encryption key with attributes. So if on one machine the secret key is stored with myattr1myval1 people can read the key with secret-tool lookup myattr1 myval1 (or search with secret-tool search --all myattr1 myval1) and then just store that key on the new machine via secret-tool store --label="Obsidian encryption key" myattr1 myval1
As an example this is how the entries on my Arch Linux machine look like for the chromium secret and the Signal one (I am using Signal Beta):
$ secret-tool search application chromium
[/53]
label = Chromium Safe Storage
secret = <redacted>
created = 2026-01-05 23:36:40
modified = 2026-01-05 23:36:40
schema = chrome_libsecret_os_crypt_password_v2
attribute.application = chromium
$ secret-tool search application Signal\ Beta
[/66]
secret = <redacted>
created = 2026-01-06 14:22:10
modified = 2026-01-06 14:22:10
attribute.application = Signal Beta
So chromium literally looks up its own secret with secret-tool lookup application chromium and Signal Beta with secret-tool lookup application "Signal Beta"
Because I was working with the Secret Service API and libsecret and KWallet recently (also fixing bugs in those libs) here is another hint I want to provide: There is this library that just lists you all the entries stored in your currently used Secret Service Provider. It uses libsecret: Grant Moyer / lssecret · GitLab Just run lssecret (and add -s to also show the secrets). If you use Arch you can use this AUR: AUR (en) - lssecret-git It’s quite helpful during dev and to figure out which secrets are stored already.
PS: Please do not forget to encrypt cookies :wink: Thanks!
Here are some links that might be helpful:
