Creating a signature block for meeting minutes
Hi, I’m creating a template to use for meeting minutes and I’d like to add a signature block to the bottom of the template so when I export the notes there is a place for the secretary to sign.
Something like this:
Signature: ____________
Date: __________
When I attempt to do it in the note, when it renders it only shows 2 or 3 underscore spaces.
Signature : __
Date: __
Any ideas on how I can make the lines longer in the output?
Thanks.
Have you tried escaping each underscore with a backslash?
eg
\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_
becomes
________________________
Bare underscores are used for bold and italics.
That works perfectly, thank you.
If you wanted it to look like a block, you could use a table.
For example:
| Signature | <img width=300/> |
| Name      |  |
| Date      |  |
Formats as:
Signature
Name
Date
Angel
Thanks Angel, that looks great.
