Hello everyone,
I use Obsidian to write quite a lot of stuff.
Is there a way (plugin or not) to create shortcuts for words or sentences?
For example, is there a way I can write “Philippe le Bel” by just writing “P4”?
Thank you
Hello everyone,
Thank you
Take a look at the plugins text snippet and text expander (I think that’s the name). They should offer functionality like you request, if I’m not mistaken.
Abbreviations Expander is a plugin that does that.
Its name does not suggest it, but also the “Latex suite” doubles as a text expansion tool.
Then there is the option of using a system wide text expansion tool, such that your expansions work everywhere. For example, Espanso is an open source cross-platform text expansion tool.
Hello everyone,
Thank you for your sugestions, I will try it
I wish you a great day or night!
Hi everyone,
I confirm that Text Expander works perfectly
Have a nice day!
