Currently, my settings are not using wiki links, and the internal link type is a relative path. But I want to use the [] syntax to create new double-linked files. In this case, the created file path is not a relative path. And link converter plug-ins cannot solve this problem.
It would be helpful to make links created with [] syntax also follow the internal link type settings.
Currently, the only workaround is to not use wiki link syntax for creating links between notes. This eliminates the convenience of wikilink creation and automatic bi-directional linking.
This issue is related to:
https://forum.obsidian.md/t/have-separate-use-markdown-links-options-for-wikilinks-and-image-links/7686?mobile_view=0
Thanks in advance !!
